    Charlyplexing or matrix
    Scheduled Pinned Locked Moved General Discussion
    19 Posts 2 Posters 10.6k Views
    • W
      Wim Stockman @Wim Stockman
      It seems the get attribute isn't implemented for the relays
      and if I do a full request it gets dump on de command line in evok.py instead of sent to the websocketclient.
      So I could initialise the position of the relays
      import websocket
      import json
      import time
      import threading
      url = "ws://127.0.0.1/ws"
      i = 0
      relaystatus = [0,0,0,0,0,0,0,0]
      #initiliaze relay 3 just for demo purpose
      wsinit = websocket.create_connection("ws://127.0.0.1/ws")
      time.sleep(2)
      wsinit.send('{"cmd":"full","dev":"relay","circuit":"3"}')
      result = json.loads(wsinit.recv())
      relaystatus[2] = result["value"]
      print relaystatus
      wsinit.close()
      def on_message(ws, message):
          obj = json.loads(message);
          dev = obj['dev'];
          print obj['dev'];
          circuit = obj['circuit'];
          value = obj['value'];
          global i
          global relaystatus
          i += 1
          print i
          if dev == 'input' and i > 2:
              print "erin";
              ws1 = websocket.WebSocket();
              ws1.connect(url);
              #sending messages
              print obj['value'];
              if relaystatus[2] == 0:
                      ws1.send('{"cmd":"set","dev":"relay","circuit":"3","value":"1"}')
                      relaystatus[2] = 1
              else:
                      ws1.send('{"cmd":"set","dev":"relay","circuit":"3","value":"0"}')
                      relaystatus[2] = 0
              i = 0
          print message
      def on_error(ws, error):
          print error
      def on_close(ws):
          print "Connection closed"
      #receiving messages
      ws = websocket.WebSocketApp(url, on_message = on_message, on_error = on_error, on_close = on_close)
      wst = threading.Thread(target=ws.run_forever())
      wst.daemon = True
      wst.start()
      while not  ws.sock.connected:
              time.sleep(5)
      This demo work for a push button that's why I have the 2 counter to activate the relay , because rising edge triggers a message as well as the falling edge. But that will come in handy for detecting how long somebody presses de button.
      Somebody know where I can begin to omplent the Get for the relays.
      Kind regards,
      Wim
        tomas_hora administrators
        @Wim-Stockman Thanks for the report. See this modification of the on_message function:
                    try:
                        device = Devices.by_name(dev, circuit)
                        # result = device.set(value)
                        func = getattr(device, cmd)
                        if value is not None:
                            result = func(value)
                        else:
                            result = func()
                        if is_future(result):
                            result = yield result
                        #devents.status(device)
                        self.write_message(result)
                        #print json.dumps(result)
                    except Exception, E:
                        print E
        It will send the result of the command to only the client that send the command. But in our test, you are using two clients, so you will not receive the result in the other client. If you want to send the result to all clients connected to the WebSocket, use the devevents.satus(device) insted.
        Working example of the test client:
        import websocket
        import json
        import time
        import threading
        i = 0
        time.sleep(2)
        while True:
          if result['dev'] == 'relay':
            print result
        wsinit.close()
        I will commit it in the first week of January.
        W 1 Reply Last reply
        • W
          Wim Stockman @tomas_hora
          Hi thx,
          This works !
          But now I get a weird exception on the evok.py on line 140 it throws an exception:
          I get "Expected bytes, unicode, or None; got <type 'int'>"
          Each time I sent a message : wsinit.send('{"cmd":"set","dev":"relay","circuit":"3","value":"1"}')
          It's like it iterates twice over the on_message loop
          my demo code is
          import websocket
          import json
          import time
          import threading
          url = "ws://127.0.0.1:8088/ws"
          i = 0
          global relaystatus
          wsinit = websocket.create_connection("ws://127.0.0.1:8088/ws")
          time.sleep(2)
          relaystatus[2]=result["value"]
          while True:
            if result['dev'] == 'input':
                  if relaystatus[2]==0 :
                     relaystatus[2] = 1
                  else:
                     wsinit.send('{"cmd":"set","dev":"relay","circuit":"3","value":"0"}')
                     relaystatus[2] = 0
            print result
          wsinit.close()
          Thanks for the great help already :-)
          Wim
          T W 2 Replies Last reply
            tomas_hora administrators @Wim Stockman
            @Wim-Stockman I saw your pull request.. Did you find out what it was with the Expected bytes, unicode, or None; got <type 'int'>"? On what code did it crash?
            • W
              So I found the problem, solved it and put a pull request in github.
              made a little change in the evok.py.
              #adding support to get state of relays using full msg in cmd
                         if cmd == "full":
              • W
                @tomas_hora yes the on_events routing fired a new message for the status change of the relay which was captured by the on_message and since it just sented a 0 or 1 the on_message gave this weird thing
                • W
                  Wim Stockman
                  • W
                    So I finished the hardware part for the input plexing.
                    I used a variation on the charlyplexing.
                    In the example breadboard I only used 4 digital inputs (symbolized by the Leds), the 12V Vcc is symbolized by the battery and 8 pushbutton : https://circuits.io/circuits/3580634-stockmaninputplexing.
                    You could attach up to 15 pushbuttons on 4 digital inputs with this method. It is just some binary logic behind and a lot of diodes :-)
                    The purple wires are connected to an input just directly. (you could place diodes for safety)
                    and the next 6 pushbuttons are connected through 2 wires.
                    If you want 4 more pushbuttons you should combine 3 wires
                    and for the last one you need 4 wires.
                    So in theory with this method you could make 16383 different input combinations with this method.
                    I think it will not be practical but with 2 wires you can easily attach up to (14²-1) 195 pushbuttons with each different reactions.
                    So know I will create a python class to handle these inputs using the websocket method :-)
                    • W
                      Wim Stockman
                      Is there a possibility to receive the inputs via websocket with timestamps.
                      I know the pigpio librabry does this, but since the new neurons don't work anymore with pigpio. I was wondering if this is possible would be easy to detect , long pressed buttons etc...
                      • W
                        Wim Stockman
                        I have written some code to detect two inputs simultaniously activated through websocket.
                        Here is the code
                        #timingclass
                        import websocket
                        import threading
                        import datetime
                        import json
                        import time
                        url = "ws://192.168.1.104:8088/ws"
                        class DI:
                        	def __init__(self,circuit,value,timestamp):
                        		self.circuit = circuit
                        		self.value = value
                        		self.timestamp = timestamp
                        		self.longpress = 0
                        		self.doubletap = 0
                        class homecontrol:
                        	def __init__(self,websock_evok_url):
                        		self.status = 0
                        		self.digitalinput_list = [[0,0],[0,0]] # create list with timestamp inputs
                        		self.timeout = 1000
                        		self.websock_evok_url = websock_evok_url
                        		#connect to websocket and spawn message thread
                        		self.ws = websocket.WebSocketApp(url, on_message = self.on_message, on_error = self.on_error, on_close = self.on_close)
                        		self.wst = threading.Thread(target=self.ws.run_forever())
                        		self.wst.daemon = True
                        		self.wst.start()
                        	def time_stamp_inputs(self):
                        			t = datetime.datetime.now()
                        			t = (t.second * 1000)+(t.microsecond / 1000)
                        			return t
                        	def detect_if_pressed_together(self):
                        		d1 = self.digitalinput_list[0]
                        		d2 = self.digitalinput_list[1]
                        		# must be two different inputs and the same values you cannot press and unpress at the same time
                        		if d1.circuit != d2.circuit and d1.value == d2.value:
                        				t = d1.timestamp -d2.timestamp
                        				if t < self.timeout:
                        					return 1
                        				else:
                        					return 0
                        	def on_message(self,ws, message):
                        			self.obj = json.loads(message)
                        			print self.obj
                        			self.dev = self.obj["dev"]
                        			self.circuit = self.obj["circuit"]
                        			self.value = self.obj['value']
                        			if self.dev == "input" and self.value == 1 :
                        				digitalinput = DI(self.circuit,self.value,self.time_stamp_inputs())
                        				self.digitalinput_list.insert(0,digitalinput)
                        				if(self.detect_if_pressed_together()):
                        					l = (self.digitalinput_list[0].circuit,self.digitalinput_list[1].circuit)
                        					l = sorted(l)
                        					x = str(l[0])+str(l[1])
                        					self.digitalinput_list[0].circuit = int(x)
                        					x = self.digitalinput_list[0]
                        					proc = threading.Thread(target=self.proceed_input,args=(x,))
                        					proc.start()
                        	def detect_long_press_of_button(self):
                        		pass
                        	def proceed_input(self,I):# SETUP a method to declare what to do which each function , was thinking of using codeblocks for this part ?
                        		  if I.circuit == 17:
                        			  print I.circuit
                        			  relay = 5
                        			  t = threading.Thread(target=self.switch_rel,args=(relay,))
                        			  #t = threading.Thread(target=switch_on_off_relay,args=(relay,))
                        			  t.start()
                        			  print "thread"
                        		  if I.circuit == 26:
                        			  print "26"
                        			  relay = 1
                        			  c = threading.Thread(target=self.switch_rel,args=(relay,))
                        			  c.start()
                        			  print "thread2"
                        	def on_error(self,ws,error):
                        			print "error"
                        			print error
                        	def on_close(self,ws):
                        			print "connection closed"
                        	def switch_rel(self,c):
                        		relaynumber = c
                        		self.ws.send('{"cmd":"set","dev":"relay","circuit":"'+str(relaynumber)+'","value":"0"}')
                        		#else:
                        		#		self.ws.send('{"cmd":"set","dev":"relay","circuit":"'+str(relaynumber)+'","value":"0"}')
                        		#		self.status = 1
                        def switch_on_off_relay(c):
                        			print c
                        			relaynumber = c
                        			ws = websocket.create_connection(url)
                        			print "swdf"
                        			ws.send('{"cmd":"set","dev":"relay","circuit":"'+str(relaynumber)+'","value":"1"}')
                        			ws.close
                        			pass
                        x = homecontrol(url)
                        But I have a problem that some inputs when they are to fast one after each other get forgetten.
                        and if I do none multithreading it does do al the steps but then one push may hold the others so not good.
                        Can somebody help me ?
                          @Wim-Stockman I will take a look at it during the next week. Thanks for the tip.
                          I did not check the code much but there should be some time buffer while decoding the correct input. The messages does not always come at the same time, there might be a tens of ms gap between each and you shoudl tie those together...
