    Cannot setup wifi connection Axon S105
    Scheduled Pinned Locked Moved Axon series
    2 Posts 2 Posters 1.5k Views 1 Watching
    • H
      heikkim
      I'm having issues setting up my axon S105 to connect to our wifi network.
      I can ssh into unipi using ethernet cable and an offline router but I cannot figure out how to enable wifi.
      unipi@S105-sn108:~$ sudo ifup wlan0
      wlan0: interface not found or invalid
      I have entered wpa settings into /etc/wpa_supplicant.conf
      also added wlan0 to /etc/network/interfaces
      I disabled Mervis and Evok using hotspot mode as we plan to use this hardware as a node.js powered i/o controller for our customers product family.
      Please, advice how to configure wifi connection / enable network interface for wlan.
      Do I need to install drivers etc.? (I have no internet connection for the ethernet port)
      unipi@S105-sn108:~$ sudo lsmod
      Module                  Size  Used by
      unipi                  98304  2
      ds2482                 16384  0
      industrialio           53248  1 unipi
      wire                   40960  1 ds2482
      cn                     16384  2 wire
      at24                   20480  0
      Thank you for your time and suggestions :)
      T 1 Reply Last reply
        tomas_hora administrators @heikkim
        @heikkim Hello, to enable wifi you should enable the interface in /boot/boot.cmd by commenting the followin lines (add a # at the beginning)
        fdt set /soc/mmc@01c10000/bcrmf@1 status "disabled"
        fdt set /soc/mmc@01c10000 status "disabled"
        Then run mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr and reboot.
        Does it work?
