    PWM output Neuron
      cvrcejir last edited by
      How can I set PWM duty to 0% on UniPi Neuron L513?
      I tried to set via EVOK webpage but value didn't change. Minimal accept value is 1% :(
      Thank you!
      Martin Kudláček 2 Replies Last reply Reply Quote 0
        Martin Kudláček administrators @cvrcejir last edited by
        Hello @cvrcejir,
        unfortunately this is an error in the REST API, not the Evok's web interface. I forwarded this issue to the programmers and let you know once it is fixed.
        Thank you for your patience,
          Hello @cvrcejir,
          we have released a new version of Evok, which fixes the error reported by you. If you have installed Evok via package manager, simply update by apt update && apt upgrade.
            cvrcejir @Martin Kudláček last edited by
            Hello @martin-kudláček,
            I made update, but problem with set pwm duty still exist. I have same problem if i use websocket API.
              Hello @cvrcejir,
              I am sorry but I have to confirm that. Moreover, the Evok 2.0.7i brought even more errors than it fixed, so please, downgrade to the 2.07h: apt install evok=2.0.7h.
              I am sorry for the troubles,
