    Boot project
      Tazok last edited by
      Hello, i have problem with creating boot project on the Mervis with raspberry 3. Boot project was created correct, but after power off and power on, dont started. Where is problem. Thanks for answer.
        Martin Kudláček administrators @Tazok last edited by
        Hello @tazok,
        can you please explain a bit more what are you trying to achieve? What SD card image do you use? Do you run it on sole RaspberryPi or do you use some of our units?
        Thanks,
          Podle jmena soudim, ze muzeme cesky :) pouzivam obraz UniPi-Neuron-Mervis-OS-2018-09-14_v1.7-BETA.zip a mam jen ciste raspberry. V Mervisu vytvorim program, nahraju a funguje, potom dam vytvoreni boot projektu, mervis napise ze byl vytvoren, avsak po restartu raspberry se program nespusti a musim ho znovu nahrat
            Dobrý den,
            je nám líto, ale podporu pro Mervis poskytujeme pouze k našim produktům.
            Děkuji za pochopení a přeji pěkný zbytek dne,
            Martin Kudláček
