    Analog Input - Evok Settings are not clear
    • S
      seecosmea last edited by
      Hi, would like to adjust evok setting for the Analog Input but found no clear instructions for this. What is possible to adjsut with the following items:
      bits=18
      gain=1
      correction = 5.558737622
      corr_rom = 1
      corr_addr = 0xf0
      For me the item "Interval" is clar only, pls let me know for what are the other items.
        tomas_hora administrators @seecosmea last edited by tomas_hora
        @seecosmea If you wish, you can set a lower bit resolution to get faster read of the AI. The correction is stored in the onboard memory (corr_rom and corr_addr), if you comment these out, you can set it manually using the correction parameter. Ignore the gain parameter.
