    pH and EC sensor
    • B
      Baggz last edited by
      Are there any pH and EC sensors that work with Neuron? Via the 1-Wire?
      Thanks in advance!
        Martin Kudláček @Baggz last edited by
        Hi @baggz,
        not that I know of. But proper pH sensors usually have a analog output, so you can connect it to UniPi Neuron's or Axon's analog input.
        From your profile I guess you want to measure the amount of nutrients in the water for flowers. If you know basic electronics stuff, I would recommend you some cheap eBay pH sensor for start, such as this. You will learn how they work and how to calibrate them, because they degrade in time.
        • B
          Baggz @Martin Kudláček last edited by
          @martin-kudláček
          Thanks a lot, Martin! :-) I'll give it a chance.
