    UniPi - Homeseer plugin
    HomeSeer
    • P
      Paroxysm last edited by
      Howdy folks,
      I have stumbled across here from a google search. I own a Unipi 1.1 and Homeseer. I originally came across a thread by ewillems as he stated he had created a plugin for Homeseer for the Unipi. His profile said he hasnt been on for quite some time now and i cannot find a working link if any to download this plugin. Would anybody have happened to grab it and can pass it on to me as i would love to be able to utilise these two together.
      Thanks in advance.
      Kind Regards
        Martin Kudláček @Paroxysm last edited by
        Hi @paroxysm,
        the post you have probably stumbled upon has been imported from old forum and the attachments didn't survive (sigh). But the old forum is still running and you can check the original post here. So try it and please, let us know, if the plugin still works with current version of Homeseer.
        Thanks!
        • P
          Paroxysm @Martin Kudláček last edited by
          @martin-kudláček Hi mate,
          Cant honestly thank you enough.
          Grabbing it now and will test shortly.
          Thanks again.
          Kind Regards
          • K
            ktanghe last edited by
            Hello, i have tried the plugin but it not seems to work.
            I can select the unipi.vb script but i do not see the buttons in the device list.
            Thank you
            • K
              May-24 8:31:20 AM
              Error
              Compiling script /usr/local/HomeSeer/scripts/unipi.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
