    INFO Codesys
      TriathletC last edited by
      Hello already for a long time we program the UNIPI via Mervis.. Now I would also start to use the Codesys.. I would like to know that image was preloaded on the Unipi... because in the Mervis there is an ISO image to be put on SD card.
        Hi @TriathletC!
        You will need to use the UniPian image for CODESYS, but you will also need to buy the CODESYS for Neuron plugin.
        For more information see the UniPi Neuron compatibility section on our CODESYS SW help section
