Same evok start error
Re: evok start error
I installed a few Unipi 1.1 and UniPi Lite 1.1's. A few days ago I want to install a new one (raspbian + evok), And I have the same problem. I tried to remove and re-install the Evok, it did not help. I re-installed everything, same result. Is there any progress with this problem?
Hi @Bart-Delaere!
It looks like the latest master commit on EVOK has a bug in that regard. We've recently added functionality to query the version of EVOK via the API, but it looks like it might be buggy.I recommend downloading a stable release by following the instructions on the GitHub page instead. I will fix the issue on the master branch today.
Indeed, I installed EVOK Release v.2.0.5c, and it works like it should ;)
Thank you very much!
@Bart-Delaere
The issue should now be fixed both in Master and in the latest release. v.2.0.5fAs a side note you can now query the version of your EVOK via /version/, though unfortunately it only applies from v.2.0.5f onwards.
