    evok start error
    • U
      unix last edited by unix
      Hi
      Fresh installed image image from 09.2017 raspian-stretch lite :
      root@raspberrypi:/home/pi# cat /etc/debian_version
      9.1
      Kernel :
      root@raspberrypi:/home/pi# uname -a
      Linux raspberrypi 4.9.41-v7+ #1023 SMP Tue Aug 8 16:00:15 BST 2017 armv7l GNU/Linux
      no apt upgrade only apt update
      after install evok from git and final reboot evok not starting .
      root@raspberrypi:/home/pi# service evok status
      ā— evok.service - Evok Modbus/Websocket/Rpc Server
         Loaded: loaded (/etc/systemd/system/evok.service; enabled; vendor preset: enabled)
         Active: failed (Result: exit-code) since Thu 2018-05-24 19:01:39 UTC; 56s ago
        Process: 503 ExecStart=/usr/bin/python /opt/evok/evok.py (code=exited, status=1/FAILURE)
       Main PID: 503 (code=exited, status=1/FAILURE)
      May 24 19:01:39 raspberrypi systemd[1]: evok.service: Service hold-off time over, scheduling restart.
      May 24 19:01:39 raspberrypi systemd[1]: Stopped Evok Modbus/Websocket/Rpc Server.
      May 24 19:01:39 raspberrypi systemd[1]: evok.service: Start request repeated too quickly.
      May 24 19:01:39 raspberrypi systemd[1]: Failed to start Evok Modbus/Websocket/Rpc Server.
      May 24 19:01:39 raspberrypi systemd[1]: evok.service: Unit entered failed state.
      May 24 19:01:39 raspberrypi systemd[1]: evok.service: Failed with result 'exit-code'.
      and
      oot@raspberrypi:/home/pi# /usr/bin/python /opt/evok/evok.py
        File "/opt/evok/evok.py", line 1239, in <module>
          class VersionHandler(UserCookieHelper, APIHandler):
        File "/opt/evok/evok.py", line 1240, in VersionHandler
          self.version = 'Unspecified'
      NameError: name 'self' is not defined
      any tips hints ?
      Regards
      Bart Delaere 1 Reply Last reply Reply Quote 0
      • U
        unix last edited by
        Hi
        after copy from the old evok version before :
        sudo cp -r tornadorpc_evok /usr/local/lib/python2.7/dist-packages
        sudo cp -r opt/* /opt/
        sudo cp -r evok/ /opt/
        unipi start and modbus running to extension
        Regards un|x
        • U
          unix last edited by
          forget to post the system defaults
          raspian-lite April 2018
          root@pimatic:~# cat /etc/debian_version
          9.4
          root@pimatic:~# uname -a
          Linux pimatic 4.14.43-v7+ #1115 SMP Fri May 25 14:27:48 BST 2018 armv7l GNU/Linux
          Regards un|x
          • Bart Delaere
            Bart Delaere @unix last edited by
            @unix
            Hi unix,
            I installed a few Unipi 1.1 and UniPi Lite 1.1's. A few days ago I want to install a new one (raspbian + evok), And I have the same problem. I tried to remove and re-install the Evok, it did not help. I re-installed everything (OS + evok), same result. You are not the only one with this problem.
            I hope there is solution soon....
            https://forum.unipi.technology/topic/669/same-evok-start-error
              @unix, @Bart-Delaere
              Reposting from the other thread, the Master branch is currently buggy:
              It looks like the latest master commit on EVOK has a bug in that regard. We've recently added functionality to query the version of EVOK via the API, but it looks like it might be buggy.
              I recommend downloading a stable release by following the instructions on the [GitHub page](https://github.com/UniPiTechnology/evok) instead. I will fix the issue on the master branch today.
              It should be fixed today within a few hours.
                TomasKnot last edited by
                @unix
                The issue should now be fixed both in Master and in the latest release. v.2.0.5f
                As a side note you can now query the version of your EVOK via /version/, though unfortunately it only applies from v.2.0.5f onwards.
