    Unipi neuron os with RS485
      jens1238 last edited by
      Hello everyone ,
      I installed the latest OS version of "unipian neuron 2018-03-09".
      Now i have my own java program , that makes a connection with the RS485 port of the neuron.
      But i was wondering , what is the tty port of the rs485 ? Ithought it was the serial0 but no respons , also i readed here on this forum that i must use /dev/extcomm/0/0 but i can't find that path.
      Can you help me to fix this ?
        TomasKnot last edited by
        You should be able to use /dev/ttyNS0.
        Hope this helps.
          Thanks !
          I will try it.
          Is it also possible to install the normal raspbian jessie version with evok ? Or must i use then a differend port ?
            tomas_hora administrators @jens1238 last edited by
            @jens1238 Not related to this task anymore.. If needed, please create a new topic. The answer is here: https://github.com/UniPiTechnology/evok#installation-process-for-the-20-evok-version
              @jens1238 @tomas_hora
              Do note that with standard Raspbian you will need to use /dev/extcomm/ instead, and will not be able to natively change the parity settings without going through Modbus.
