    AO signal 0-10 V in parallel
    Neuron Series
      TriathletC last edited by
      Sorry guys you can drive two modulating valves 0-10v with a single AO signal of the neuron? Put the parallel signal from problems at the analog output? does it hold the load?
      I need to know this because I definitely have to drive in parallel with a single 0-10v signal two fancoil with inverter ..
        tomas_hora administrators @TriathletC last edited by
        @TriathletC The maximum output current is 20mA. Check the load of the fan coils if it's enough (but it should be).
          Tanks.I check
