    Relay problem
    • MMCreativ
      MMCreativ last edited by
      Hello, I start with unipi neuron M103 and i don't understand how to connect light on relay output, evok is install and when i switch the relay position in the web interface, relay led is lighting but my light not switch state ... Can you help me ?
        Can you post a diagram of how you connected the light? If the light is an LED panel you may have to use a specialised external relay, as LED panels can have very high inrush current (>3 orders of magnitude higher than operating current usually).
