    Key word INIT
      RainerK last edited by
      I try to get the OSCAT Libs to work in Mervis.
      Example: FUNCTION_BLOCK _RMP_B
      VAR
      tx, tl, tn : TIME;
      init : BOOL;
      last_dir : BOOL;
      start : BYTE;
      END_VAR
      Error: In 'variables declaration', missing 'Keyword_END_VAR' at ''init''
      Error In 'init block', mismatched input '':'', expecting 'Keyword_END_INIT'
      Error In 'typed bit string literal', mismatched input '';'', expecting 'Special_HASH'
      T 1 Reply Last reply Reply Quote 1
        tomas_hora administrators @RainerK last edited by tomas_hora
        @RainerK The function block declaration in Mervis requires the following schema but the INIT variable name to must not be used. This is a bug of course that needs to be fixed. But thanks for the info. I saw that you have already reported the issue via the Mervis report form.
        FUNCTION_BLOCK fb_name
        EXTENDS //base type
        IMPLEMENTS //interface type list
        	VAR
        		(* add local variables here *)
        	END_VAR
        	VAR_INPUT
        		(* add in variables here *)
        	END_VAR
        	VAR_OUTPUT
        		(* add out variables here *)
        	END_VAR
        METHOD abc //: return type
          // method's body
        END_METHOD
        (*function block body*)
        END_FUNCTION_BLOCK```
