    Firmware upgrade on L503
    Neuron Series
      Jurij last edited by
      I want to know how can I upgrade firmware on Neuron L503.
      Thanks.
      Jurij
        tomas_hora administrators @Jurij last edited by Martin Kudláček
        @Jurij Firmware for PLCs isdistributed inside our images. If you boot UniPi with the latest UniPian, it will automatically flash the latest version. If you want to upgrade FW on extensions, you have to do that using our FW upgrade tool and a USB-RS485 converter.
        IMPORTANT NOTE:
        As of 2019, this is no longer true. The firmware can be upgraded only manually via SSH.
          Ok, thank you.
          • O
            origami last edited by
            ist this the same prcedure for the unipi 1.1? only to be sure. load the image to a ney sd card put in the sd slot and boot the system? after booting use the old sd card for running fhem...?
              Martin Kudláček @origami last edited by
              Hello @origami,
              the UniPi 1.1 doesn't need any firmware. To use the newest set of tools, do full update & upgrade of the operating system.
