    json rest problem
    3633
      juntiedt last edited by tomas_hora
      I am trying to run the following code. Unfortunately no success.
      Apppreciate very much your support.
      Hannes
      import http.client
      payload = "{\"value\" : \"1\"}"
      headers = {'content-type': "application/json"}
      conn = http.client.HTTPConnection("localhost:8080")
      conn.request("POST", "/json/relay/%7B5%7D", payload, headers)
      response = conn.getresponse()
      print(response.status, response.reason)
      data = response.read()
      conn.close()
      print(data)
      Error report:
        File "/home/pi/json_rest_0.py", line 7, in <module>
        File "/usr/lib/python3.5/http/client.py", line 1107, in request
          self._send_request(method, url, body, headers)
        File "/usr/lib/python3.5/http/client.py", line 1152, in _send_request
          self.endheaders(body)
        File "/usr/lib/python3.5/http/client.py", line 1103, in endheaders
          self._send_output(message_body)
        File "/usr/lib/python3.5/http/client.py", line 934, in _send_output
          self.send(msg)
        File "/usr/lib/python3.5/http/client.py", line 877, in send
          self.connect()
        File "/usr/lib/python3.5/http/client.py", line 849, in connect
          (self.host,self.port), self.timeout, self.source_address)
        File "/usr/lib/python3.5/socket.py", line 712, in create_connection
          raise err
        File "/usr/lib/python3.5/socket.py", line 703, in create_connection
          sock.connect(sa)
      ConnectionRefusedError: [Errno 111] Connection refused
        @juntiedt Try it with:
        conn.request("POST", "/json/relay/5", payload, headers)
        and according to the
        it seems that the client cannot connect to the server (check the IP address and port) and if evok is running (systemctl status evok).
          Hi Tomas,
          when I use localhost:8080 I receive the very long error message above. However, when I use localhost:80 and your request I receive the error message below. Does this tell you something?
          regards
          Hannes
          import http.client
          payload = "{\"value\":\"1\"}"
          headers = {'content-type':"application/json"}
          conn = http.client.HTTPConnection("localhost:80")
          print(data)
          conn.close()
          I get this respones:
          404 Not Found
          b'<html><title>404: Not Found</title><body>404: Not Found</body></html>'
            tomas_hora administrators @juntiedt last edited by
            @juntiedt Are you sure that evok is running on localhost on port 8080?
              evoc is running. I checked it with "systemctl status evok"
              I checked "/etc/evoc.conf. port" which was set to 80. Actually I haven't changed anything since installation! Changed it now to 8080.
              I am getting the same response as before: 404 Not Found ... see above - but now on port 8080
              Is there another file where I should/could change the port to 8080?
              does body mean payload and title mean headers?
              T T 2 Replies Last reply Reply Quote 0
                TomasKnot @juntiedt last edited by
                This post is deleted!
                  @juntiedt After you changed the port in /etc/evok.conf to 8080, did you restart it? I think it should not work, because there is the some webserver running on 8080. Check it with
                  netstat -putan
                    is it possible that I have a problem with tornadorpc-evok. I am not sure if it is installed the correct way. please let me know how to install it and where I can find the correct installation file.
                    regarding your question: no web server running
                      @juntiedt Some server is running because it responds with 404... The tornado-rpc evok is part of evok itself. Please try to reinstall evok and paste the output of the installation script
                        ok, I will reinstall evok.
                        Wich one would you recommend?
                        Legacy or Evok 2.0 on my unipi1.1 with stretch
                          @juntiedt 2.0
                            new stretch image, new evok --> all works perfectly!
                            thanks Tomas
                              Hi Tomas,
                              I was too optimistic yesterday. Today I tryed your websocket based sample programm with Python 3. Python can't find websocket. Do I have to install a websocket library? If yes which one?
                              There is another problem I found when rebooting after installing evok.
                              During booting raspbian stretch I got this warning message:
                              "Failed to start load kernel modules"
                              Could this be the reason why websocket does not work?
                              I am running plain stretch with latest update and upgrade
                                system Status:
                                ● systemd-modules-load.service - Load Kernel Modules
                                   Loaded: loaded (/lib/systemd/system/systemd-modules-load.service; static; vendor preset: enabled)
                                   Active: failed (Result: exit-code) since Fri 2017-11-17 12:50:58 CET; 2min 17s ago
                                     Docs: man:systemd-modules-load.service(8)
                                           man:modules-load.d(5)
                                  Process: 126 ExecStart=/lib/systemd/systemd-modules-load (code=exited, status=1/FAILURE)
                                 Main PID: 126 (code=exited, status=1/FAILURE)
                                Nov 17 12:50:58 raspberrypi systemd-modules-load[126]: Inserted module 'i2c_dev'
                                Nov 17 12:50:58 raspberrypi systemd-modules-load[126]: Inserted module 'i2c_bcm2708'
                                Nov 17 12:50:58 raspberrypi systemd-modules-load[126]: Error running install command for unipi_eprom
                                Nov 17 12:50:58 raspberrypi systemd-modules-load[126]: Failed to insert 'unipi_eprom': No such file or directory
                                Nov 17 12:50:58 raspberrypi systemd-modules-load[126]: /etc/opt/unipi_eprom: 24: /etc/opt/unipi_eprom: cannot create /sys/class/i2c-dev/i2c-1/device/new_device: Directory none
                                Nov 17 12:50:58 raspberrypi systemd-modules-load[126]: sh: 1: cannot create /sys/bus/i2c/devices/i2c-1/new_device: Directory nonexistent
                                Nov 17 12:50:58 raspberrypi systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
                                Nov 17 12:50:58 raspberrypi systemd[1]: Failed to start Load Kernel Modules.
                                Nov 17 12:50:58 raspberrypi systemd[1]: systemd-modules-load.service: Unit entered failed state.
                                Nov 17 12:50:58 raspberrypi systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
                                  sorry for the websocket issue. Its now running.
                                  the only thing left is the unipi_eprom problem in the boot process of Raspbian
