    json rest problem
    6540
      tomas_hora administrators @juntiedt last edited by
      @juntiedt Are you sure that evok is running on localhost on port 8080?
        evoc is running. I checked it with "systemctl status evok"
        I checked "/etc/evoc.conf. port" which was set to 80. Actually I haven't changed anything since installation! Changed it now to 8080.
        I am getting the same response as before: 404 Not Found ... see above - but now on port 8080
        Is there another file where I should/could change the port to 8080?
        does body mean payload and title mean headers?
        T T 2 Replies Last reply Reply Quote 0
          TomasKnot @juntiedt last edited by
            @juntiedt After you changed the port in /etc/evok.conf to 8080, did you restart it? I think it should not work, because there is the some webserver running on 8080. Check it with
            netstat -putan
              is it possible that I have a problem with tornadorpc-evok. I am not sure if it is installed the correct way. please let me know how to install it and where I can find the correct installation file.
              regarding your question: no web server running
                @juntiedt Some server is running because it responds with 404... The tornado-rpc evok is part of evok itself. Please try to reinstall evok and paste the output of the installation script
                  ok, I will reinstall evok.
                  Wich one would you recommend?
                  Legacy or Evok 2.0 on my unipi1.1 with stretch
                    @juntiedt 2.0
                      new stretch image, new evok --> all works perfectly!
                      thanks Tomas
                        I was too optimistic yesterday. Today I tryed your websocket based sample programm with Python 3. Python can't find websocket. Do I have to install a websocket library? If yes which one?
                        There is another problem I found when rebooting after installing evok.
                        During booting raspbian stretch I got this warning message:
                        "Failed to start load kernel modules"
                        Could this be the reason why websocket does not work?
                        I am running plain stretch with latest update and upgrade
                          system Status:
                          ● systemd-modules-load.service - Load Kernel Modules
                             Loaded: loaded (/lib/systemd/system/systemd-modules-load.service; static; vendor preset: enabled)
                             Active: failed (Result: exit-code) since Fri 2017-11-17 12:50:58 CET; 2min 17s ago
                               Docs: man:systemd-modules-load.service(8)
                                     man:modules-load.d(5)
                            Process: 126 ExecStart=/lib/systemd/systemd-modules-load (code=exited, status=1/FAILURE)
                           Main PID: 126 (code=exited, status=1/FAILURE)
                          Nov 17 12:50:58 raspberrypi systemd-modules-load[126]: Inserted module 'i2c_dev'
                          Nov 17 12:50:58 raspberrypi systemd-modules-load[126]: Inserted module 'i2c_bcm2708'
                          Nov 17 12:50:58 raspberrypi systemd-modules-load[126]: Error running install command for unipi_eprom
                          Nov 17 12:50:58 raspberrypi systemd-modules-load[126]: Failed to insert 'unipi_eprom': No such file or directory
                          Nov 17 12:50:58 raspberrypi systemd-modules-load[126]: /etc/opt/unipi_eprom: 24: /etc/opt/unipi_eprom: cannot create /sys/class/i2c-dev/i2c-1/device/new_device: Directory none
                          Nov 17 12:50:58 raspberrypi systemd-modules-load[126]: sh: 1: cannot create /sys/bus/i2c/devices/i2c-1/new_device: Directory nonexistent
                          Nov 17 12:50:58 raspberrypi systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
                          Nov 17 12:50:58 raspberrypi systemd[1]: Failed to start Load Kernel Modules.
                          Nov 17 12:50:58 raspberrypi systemd[1]: systemd-modules-load.service: Unit entered failed state.
                          Nov 17 12:50:58 raspberrypi systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
                            sorry for the websocket issue. Its now running.
                            the only thing left is the unipi_eprom problem in the boot process of Raspbian
