    Evok does not display data from sensor the DS18B20 but in Mervis or raspbery it do
    General Discussion
    • K
      KaniaGandzowski last edited by KaniaGandzowski
      I have got UniPI and raspberry PI 3.
      I want read temp from evok api
      root@unipi:/sys/bus/w1/devices# wget -qO- http://10.2.11.149:8088/rest/sensor/1
      {"interval": 1, "value": null, "circuit": "1", "address": "280416C20BF3FF", "time": 0, "typ": "DS18B20", "lost": false, "dev": "temp"}root@unipi:/sys/bus/w1/devices#
      value is empty (null) but in
      root@unipi:/sys/bus/w1/devices/28-0416c20bf3ff# cat name
      28-0416c20bf3ff
      root@unipi:/sys/bus/w1/devices/28-0416c20bf3ff# cat w1_slave
      c7 01 4b 46 7f ff 0c 10 fe : crc=fe YES
      c7 01 4b 46 7f ff 0c 10 fe t=28437
      And can read from Mervis
      My file evok.conf
      /etc/evok.conf
      #!! don't use # for inline comments
      [MAIN]
      webname = unipi
      staticfiles = /var/www/evok
      ;password = test
      ;rpcpassword = test
      secret = ut5kB3hhf6VmZCujXGQ5ZHb1EAfiXHcy
      port = 8088
      enable_cors = False
      cors_domains = *
      modbus_port = 5020
      #modbus_address = 127.0.0.1
      modbus_address = *
      [OWBUS_1]
      owbus = --i2c=/dev/i2c-1:ALL
      interval = 3
      scan_interval = 300
      [SENSOR_1]
      bus = 1
      address = 280416C20BF3FF
      type = DS18B20
      interval = 1
      [SENSOR_2]
      bus = 1
      address = 280516b57798ff
      type = DS18B20
      interval = 2
        tomas_hora administrators @KaniaGandzowski last edited by
        @KaniaGandzowski Does the sensor shows up in the web interface of evok or in the output when evok is run on hand? It might NOT work if you have all three softwares on one system running at the same time..
        • K
          no
          does Mervis has an api? or how connect with zabbix
            @KaniaGandzowski The easies API for Mervis is TCP Modbus. What about my comment: It might NOT work if you have all three softwares on one system running at the same time..
