    UNIPI V1.1 Lite
    • H
      HEMS last edited by
      Hi everybody,
      UNIPI V1.1 Lite suits perfectly my needs for a home automation system we are planning to realize. Can anybody give me a hint whether the Codesys plugin "https://store.codesys.com/codesys-for-unipi.html" is compatible with UNIPI V1.1 Lite. From what I've read so far it's compatible with the full version UNIPI V1.1. Is there some major differences that render the Lite version incompatible?
      If anybody testet it or if anybody can give me an anser I would be very grateful. Thanks a lot!
        tomas_hora administrators @HEMS last edited by
        @HEMS Technically it should work since everything is the same as on the non-lite version so you will just not use the things that are missing... But that is just what I think. @DavidCozens will tell you more about it.
          DavidCozens last edited by
          Given what @tomas_hora states then CODESYS for UniPi should work with UniPi V1.1 Lite. However I do not have the hardware and have not tested it.
            DavidCozens @DavidCozens last edited by
            @DavidCozens I just stumbled across this old thread. I can confirm that CODESYS for UniPi does work on the UniPi Lite, just ignore the parameters for IO that is not fitted.
