    Unipi 1.1 + Codesys + OpenHAb
    OpenHAB
      c.man last edited by
      is there any example of Unipi 1.1 programmed with Codesys and OpenHAB ?
        tomas_hora administrators @c.man last edited by
        @c.man Nothing that I am aware of... But there is Codesys for UniPi 1 so you will just need to get the interface bettween codesys and openhab - TCP Modbus?
          Can you explain it better?
            @c.man The codesys package for Unipi is working well. But you will need to figure out the way how to communicate between codesys and OpenHAB. And for that, I would recommend using Mobus TCP - create a TCP Modbus server in Codesys, map the variables you want to have available in OpenHAB to the Modbus registers and read/write to/from them in OpenHAB... Or you already have that solved?
