    Change 1wire sensors refresh interval UniPi Neuron S103
    • roberts_lando
      roberts_lando last edited by
      Is there a way to manually change 1wire sensors refresh interval in UniPi Neuron? It is set to 15s by default. Would be nice also to have a button or an API in Evok to force the refresh of 1wire sensors, is there a feature like this too? Thanks
        @roberts_lando There is a default-interval parameter for each newly discovered sensor which is 3s... So it it wierd that you are getting values only every 15s. How many sensors do you have on the 1Wire bus?
        https://github.com/UniPiTechnology/evok/blob/master/etc/evok-lite.conf#L19
        • roberts_lando
          roberts_lando @tomas_hora last edited by
          @tomas_hora Maybe 15s is the refresh time of the Evok UI values not real values? I haven't checked this. Anyway I noticed that if a 1wire device is disconnected it is keep in "1Wire Sensors/Devices", how can I remove it from there or force a refresh of the list?
            @roberts_lando The values are updated on the web interface over websocket as soon as it is red from the sensor... So there should be no delay in it. Have you tried changing the temperature rapidly?
            Right there is no support for removing the sensor from the list. But there is a parameter in the message from evok to the web ui that the sensor is lost...
