    Raspbian Node-red Support
    Ubuntu Core
    • S
      sjp770 last edited by
      I am trying to get direct access to the Digital In and the relays on the UniPi through Node-red. If I run an i2c scan I can see all the devices as specified in the hardware manual. I can connect I01-I06 & I11 through the rpi-gpio nodes, but no more. Any tips for disabling SPI to free up the other gpio ports? I havn't done the cabling mod for pins 13&14 yet but plan to.
      If I can interface with the hardware on the UniPi 1.1 directly I would prefer this as the only reason to use EVOK would be to get the inputs and outputs into Node-red... this would mean i'd skip all the EVOK stuff, less to reconfigure in the case of a hardware failure and less to go wrong software wise.
        tomas_hora administrators @sjp770 last edited by
        @sjp770 https://www.raspberrypi.org/documentation/hardware/raspberrypi/spi/README.md and also by rpi-config tool
        • S
          sjp770 @tomas_hora last edited by
          @tomas_hora Thanks for the link but it doesn't explain why the gpio ports are unavailable when SPI is disabled. I used the raspi-config method.
          • S
            sjp770 @sjp770 last edited by
            @sjp770 Ended up being a newer version of Node-Red was required.
            I2C relays are still a pain if anyone find a node based solution to those.
