    Modbus pause between telegrams
    5 Posts 2 Posters 3.2k Views
    • G
      Giamba
      Hi !
      Please, do you know why when I put 30s to pause between telegrams in modbus chanel, I always have a short delay:
      21:59:55.6940 => Sending: 00 A1 00 00 00 06 00 03 00 00 00 08
      21:59:55.7040 <= Receiving: 00 A1 00 00 00 13 00 03 10 03 F2 00 E5 01 FE 00 E4 02 8A 00 00 00 00 03 84
      21:59:56.2240 => Sending: 00 A2 00 00 00 06 00 03 00 00 00 08
      21:59:56.2340 <= Receiving: 00 A2 00 00 00 13 00 03 10 03 F2 00 E5 01 FE 00 E4 02 8A 00 00 00 00 03 84
      21:59:56.7540 => Sending: 00 A3 00 00 00 06 00 03 00 00 00 08
      21:59:56.7640 <= Receiving: 00 A3 00 00 00 13 00 03 10 03 F2 00 E5 01 FE 00 E4 02 8A 00 00 00 00 03 84
      21:59:57.2840 => Sending: 00 A4 00 00 00 06 00 03 00 00 00 08
      21:59:57.2940 <= Receiving: 00 A4 00 00 00 13 00 03 10 03 F2 00 E5 01 FE 00 E4 02 8A 00 00 00 00 03 84
      T 1 Reply Last reply
        tomas_hora administrators @Giamba
        @Giamba It's not 30s but 0.5s. Check the read/write interval in the definition of the device...
        • G
          Giamba
          Ok, thanks, I find it!
          But, so, what's de "pause between telegrams" parameter ?
            @Giamba The pause between telegrams can be used when communicating with devices that you send a command to make some measurement and the measurement takes some time and only after that time you can read the measured value. Then you use the pause between telegrams property.
            • G
              Giamba
              Ok thanks for your remply!
