    More than 1 xSxx on RS485
    UniPi Extension Modules (Axon & Neuron)
    13394
    • P
      proceau last edited by
      i'm try to build S103 + xS10 + xS30 + xS40 in this order but not works
      With only S103 + xS10 ( with software configuration = all dip to 0 ) it's works fine, but it's change any dip it's don't works
      set xS10 with DIP Off / Off / On / Off / Off / Off / Off / Off = NoEnd + Addr 1 + 19K + Even
      set xS30 with DIP Off / Off / Off / On / Off / Off / Off / Off = NoEnd + Addr 2 + 19K + Even
      set xS40 with DIP On / Off / On / On / Off / Off / Off / Off = End + Addr 3 + 19K + Even
      On S103 = Dip On = End
      On Mervis = create serial with Modbus / Serial / on S103...RS485, 19K, Parity Even, Stop One
      For HW connectivité use Pair take in RJ45 cable, and all it's fixe on DIN rail
      A = A = A = A and B = B = B = B
      Not works, in system monitor all trame it's "WRONG"
      In Documentation no information for Stop Bit, and no information for DIP S103
      W 1 Reply Last reply Reply Quote 0
      • W
        wizro_pl @proceau last edited by
        @proceau I have the same problem with xS10 using another MODBUS RTU tool on Linux
        when address bits all are off then led RX indicate incoming frames (but still xS10 doesn't respond for command over modbus)
        I saw firmeware on [https://files.unipi.technology/s/public?path=%2FProducts%2FNeuron%2FFirmware](link url)
        where on changelog.txt is the information about
        " CHANGED:
        • Modbus configuration register change
          does it fix a problem? If yes which firmware is proper for xS10?
          tomas_hora administrators @wizro_pl last edited by
          @wizro_pl The software(default) parameters for extension when the address is set to 0 are: 19200, no parity, 8data bits.
          If you set the address using dip switch to other than 0, than all the hardware configuration is applied. There was an issue at some older firmwares, that the polarity of speed or parity was different than the desrciption on the case. If you hava a USB-RS485 converter, you can reflash the firmware using the Utility.
          Also make sure that you have the newest images which implement proper handling of the Serial lines so the configuration of the parameters are no longer needed to be configured via the UART config register on Neuron PLC.
          • W
            Where I can find a lastes firmware for xS10, folder "latest" is empty
            https://files.unipi.technology/s/public?path=%2FProducts%2FNeuron%2FFirmware%2Flatest
            I have xS10 SN:0000000001 (probably it is the oldest)
            "There was an issue at some older firmwares, that the polarity of speed or parity was different than the desrciption on the case." -how should I set speed and polarity to get connection without reflashing firmware?
            Strange is:
            When I set address on dip switch, RX on xS10 doesn't indicate communication. When address is set to 0 than RX on xS10 indicate communication.
              @wizro_pl and @proceau I am sorry but in some cases of the Neuron xS, there has been an issue that the firmware which we use for testing has been left there instead of reflashing to the production FW.
              If you have the USB-RS485, please use the neuron_extension_FW_tool and reflash it on your own. If not, please let us know on our email and we will reflash the unit for you if you ship it back to us.
              We are sorry for the inconveniences.
              • W
                wizro_pl @tomas_hora last edited by
                @tomas_hora
                I didn't do it because your application is going crash after put flash button.
                Yesterday, I back to investigate and tried to flash it using fwserial without success (according to this [https://forum.unipi.technology/topic/693/multiple-xs50-on-a-l513-rs485/20](link url)).
                Also, I found out why windows application going crash because programmer do not support exception when the necessary file does not exist (!!) "E-8Di8Ro-0_P-11DiR485-1.bin"
                Here is the result from fwserial:
                root@L203-sn18:/home/pi/unipi-bin# /opt/neuron-bin/fwserial -p /dev/ttyUSB0 -PR
                Boardset: 4 E-8Di8Ro_P-11DiR485 (v1.0)
                Baseboard: 1 E-8Di8Ro (v0.2)
                Firmware: v4.9
                Modbus timeout set
                error opening firmware file "/opt/fw/E-8Di8Ro-0_P-11DiR485-1.bin"
                I've used usbconverter RS485 because I had problem with communication using buildiin RS485 in Neuron.
                I tried with "UniPian-Neuron-OS-2018-03-09.img" and also directly download from https://git.unipi.technology/UniPi/unipi-bin/fw
                There is no file "E-8Di8Ro-0_P-11DiR485-1.bin"
                Here is a search result:
                root@L203-sn18:/home/pi# find / -name "E-8Di8Ro-*.bin"
                /home/pi/unipi-bin/fwx/400-400/E-8Di8Ro-1C.bin
                /home/pi/unipi-bin/fwx/1000-2000/E-8Di8Ro-0C.bin
                /home/pi/unipi-bin/fwx/1000-2000/E-8Di8Ro-1C.bin
                /home/pi/unipi-bin/fwx/400-2000/E-8Di8Ro-1C.bin
                /home/pi/unipi-bin/fw/E-8Di8Ro-1_P-11DiR485-1.bin
                /home/pi/unipi-bin/fw/E-8Di8Ro-1C.bin
                /home/pi/unipi-bin/fw/E-8Di8Ro-1.bin
                /opt/neuron-bin/fw/E-8Di8Ro-1_P-11DiR485-1.bin
                /opt/neuron-bin/fw/E-8Di8Ro-1C.bin
                /opt/neuron-bin/fw/E-8Di8Ro-1.bin
                file "E-8Di8Ro-1_P-11DiR485-1.bin" is not suitable.
                  Martin Kudláček @wizro_pl last edited by Martin Kudláček
                  Hello @wizro_pl,
                  please, follow these instructions:
                  • download the MervisOS v1.7 image from here
                  • save it to the SD card
                  • put it into your PLC, start it and SSH into it (user: unipi, password: unipi.technology)
                  • switch to the root user: sudo bash
                  • update the packages: apt update && apt upgrade
                  • reboot the unit and SSH into it again and switch to the root user
                  • stop the Mervis: systemctl stop mervisrt
                  • connect the extension to the RS485 port
                  • run the firmware flashing: /opt/unipi-bin/fwserial -p /dev/extcomm/0/0 -PR
                  • ... and post the result back here.
                  Thank you for your patience,
                    Hello @Martin-Kudláček @wizro_pl,
                    As an addendum, if the above doesn't work, please use these commands before the last step:
                    sudo bash
                    cd /opt/unipi-bin/fw
                    ln -s E-8Di8Ro-1_P-11DiR485-1.bin E-8Di8Ro-0_P-11DiR485-1.bin
                    ln -s E-8Di8Ro-1_P-11DiR485-1.rw E-8Di8Ro-0_P-11DiR485-1.rw
                    and then run the flashing command again, i.e.:
                    sudo bash
                    It looks like this is one of the first extension boards we've sent out, and so has an older firmware with a slightly different name, apologies.
                    • W
                      wizro_pl @Martin Kudláček last edited by wizro_pl
                      @martin-kudláček said in More than 1 xSxx on RS485:
                      How to enable SSH ? (probably by defualt is diable)\
                      @TomasKnot I did change ealier and got "invalid address" or something like that.
                      • W
                        wizro_pl @wizro_pl last edited by
                        ok, I enabled sshd
                        I did update & upgrade, reboot.
                        Here is your feedback
                        root@L203-sn18:/var/home/unipi# systemctl stop mervisrt
                        root@L203-sn18:/var/home/unipi# /opt/unipi-bin/fwserial -p /dev/extcomm/0/0 -PR
                        Firmware: v4.9
                        Modbus timeout set
                        Program mode setting failed: Illegal data address
                        root@L203-sn18:/var/home/unipi# cd /opt/unipi-bin/fw
                        bash: cd: /opt/unipi-bin/fw: No such file or directory
                        root@L203-sn18:/var/home/unipi# ln -s E-8Di8Ro-1_P-11DiR485-1.bin E-8Di8Ro-0_P-11DiR485-1.bin
                        root@L203-sn18:/var/home/unipi# ln -s E-8Di8Ro-1_P-11DiR485-1.rw E-8Di8Ro-0_P-11DiR485-1.rw
                        Firmware: v4.9
                        Modbus timeout set
                        and I tried
                        root@L203-sn18:/opt# cd fw
                        root@L203-sn18:/opt/fw# ln -s E-8Di8Ro-1_P-11DiR485-1.bin E-8Di8Ro-0_P-11DiR485-1.bin
                        ln: failed to create symbolic link 'E-8Di8Ro-0_P-11DiR485-1.bin': Read-only file system
                        root@L203-sn18:/opt/fw# ln -s E-8Di8Ro-1_P-11DiR485-1.rw E-8Di8Ro-0_P-11DiR485-1.rw
                        ln: failed to create symbolic link 'E-8Di8Ro-0_P-11DiR485-1.rw': Read-only file system
                        root@L203-sn18:/opt/fw# remount rw
                        root@L203-sn18:/opt/fw# /opt/unipi-bin/fwserial -p /dev/extcomm/0/0 -PR -d /opt/fw
                        Firmware: v4.9
                        Modbus timeout set
                        I see this version not need "E-8Di8Ro-0_P-11DiR485-1.rw" but it still not proper version.
                        • W
                          Do you have any sugestion what should we do now?
                            TomasKnot last edited by
                            Would it be possible to schedule a remote support session over TeamViewer? It seems like it might be the best solution, it's hard to know exactly what has gone wrong in your case.
                            I will contact you via a personal message regarding the time and other details.
                            • W
                              We can do. Yesterday I sent you the private message.
                              • W
                                When we can do something with that?
                                  Apologies, I had taken time off for personal reasons for the last two days. I will be here over the next two weeks every day.
