    1-wire extension module
    Unipi Extension Modules
    4288
    • P
      pavel.cernocky last edited by
      will there be any 1-wire extension module for Neuron?
      I mean something like "8channel 1Wire" https://www.unipi.technology/cs/8channel-1wire-rozsireni-p47?categoryId=14
      Thanks,
      Pavel
        tomas_hora administrators @pavel.cernocky last edited by
        @pavel.cernocky Such extension is not on top our todo list right now. But we will try to provide similar solution for Neurons
        • P
          What do you mean by "similar solution"?
          If it's not priority, what's preferred way to connect multiple thermometers to Neuron?
          Thank you.
            @pavel.cernocky If fiveteen 1wire sensors is not enought, you can use also analog temperature sensors in our 500 series (xS50, L503...). Maybe like a Modbus extension... There are already some available on the market.
            • P
              pavel.cernocky @tomas_hora last edited by
              @tomas_hora OK, thanks for hints.
              • S
                sidoor last edited by
                Hello
                Does '1-Wire 8 port hub' fits to neuron device? I need to connect around 30-40 DS18B20 sensors to Neuron, will it work. Maybe you know some other device which allows to switch beetwen 1-wire lines (build of 4-5 sensors each) to avoid creating too long 1-wire network?
                  tomas_hora administrators @sidoor last edited by
                  @sidoor It might work but it always depends on in what environment the installation is done. You can just cut the RS45 connectors and do the wiring in the standardized clamps
