    1Wire on L203 in Mervis
      Meethos last edited by
      I am trying to configure 1wire temp sensors on L203, but I still have problems. Could you please help me to add 1Wire channel in Mervis for L203 ? I try to use tutorial from YT - create 1W channel, add sensor, set commision mode and than assigne 1W sensor. Till there all is OK. But if i sync this configuration and start debuging mode, there are no values from sensors. Also I can not see 1W sensor as variable in program design.
      Any idea, what i did wrong ?
      Thank you.
        tomas_hora administrators @Meethos last edited by
        @Meethos If you are in full mode, then the datapoints are not generated. Try to set autogen - this will create variable and assign it to the hw.
