    Codesys emo R8 device
    2560
    • Alverman
      Alverman last edited by
      But there is no CoDeSys device for emo r8?
        tomas_hora administrators @Alverman last edited by
        @Alverman The Emo-R8 is basically the same as UniPi Relays module, you just need to set the address that you configured using the onboard
        • Alverman
          ok,
          but in CoDeSys which imposed the address?
          The address should be set to the page I / O mapping?
          I have tried to set under address% QB1 but when the active output of the relay unipi 1.1 vibrates.
          How should I set the address if the emo r8 is set to address Hex 21 or 33 Dec?
          Thank you, Alberto
            Ok, sorry. I thought that the address can changed but it is not. Since we are not the developers of the package for Codesys, you would have to ask the developer. http://store.codesys.com/codesys-for-unipi.html#Support
            • Alverman
              Excuse me but you, why should I ask CoDeSys?
              you have not developed UNIPI for CoDeSys?
              Then you should have to implement your cards or not?
              Why CoDeSys?
              Alberto
                tomas_hora administrators @Alverman last edited by tomas_hora
                @Alverman You should not contact Codesys, but the author of the package - [email protected]
                We did not develop the package.
                  DavidCozens last edited by
                  A driver for the EMO-R8 is under development and will be released later this year
                  • F
                    FabioIT last edited by
                    Any news about the driver?I know codesys is not supported but is still working ? I bought a Codesys license and with unipi 1.1 and EMO.R8 ? I need try the driver!
                      Martin Kudláček @FabioIT last edited by
                      Hello @FabioIT,
                      the development of Codesys support has been dropped altogether. The Codesys can be still used on Neuron via ModbusTCP. The Unipi 1.1 doesn't have IOs accessible via ModbusTCP, only scattered over I2C, GPIO and so on - nothing easily configurable.
