systemctl enable evok throws error in install script
Installation scripts fails on
Throws error 'Failed to execute operation: Invalid argument'.
This problem is caused by the line
Alias=evok.service
in the evok.service file.
I believe the problem is the alias refers to the same name as the name of the file. I removed the line and then everything is OK.
@ubee Thanks for the tip! I will take a look at it.
