    HMI cant make connection
      Jan Mol last edited by
      I am using Mervis IDE version 2.0.10 (52674) from Your download directory. When I want to make a connection I get:
      Error during retrieving variables: ESG.SharkPLC.ExecutableImage.ExecutableImageException: Invalid image.
      bij ESG.SharkPLC.ExecutableImage.SharkExecutableImage.ReadSectionInfo(Endianness endianness, BinaryReader br, Boolean alignTo8Bytes)
      bij ESG.SharkPLC.ExecutableImage.SharkExecutableImage.ReadContent(BinaryReader br, Boolean strippedImage)
      bij ESG.SharkPLC.ExecutableImage.SharkExecutableImage.ReadFromStream(Stream stream, Boolean strippedImage)
      bij ESG.SharkPLC.ExecutableImage.SharkExecutableImage.ReadFromFile(String fileName, Boolean strippedImage)
      bij ESG.RcWare.SCADA.Application.Shared.Variables.SharkImageVariablesProvider.Retrieve()
      on the new .exs file
      Mervis HMI version is 0.9.16.715
      Kind Regards
      Jan Mol
        tomas_hora administrators @Jan Mol last edited by
        @Jan-Mol Could you please describe it a little bit more in details? Where is this error log taken from and what .exs file do you mean?
          Very simple:
          Make a new HMI project, select a new image and then try to get a analog indicator from your MDI project into your image.
          You have to make a connection (mostly default connection) in the properties to a so called shark image file (.exs) from your (perfect running) Mervis IDE project with software version 2.0.10.52674. At the moment that you click 'retrieve' to get a list off all parameters in the MDI you will get this error.
          At this moment is is not possible to make a HMI project with HMI version 0.9.16.715 from a MDI project with version 2.0.10.52674
          Kind Regards,
          Jan Mol
