    Error using "jsonrpclib"
      moeins last edited by
      this is my code:
      import websocket
      import json
      from jsonrpclib import Server
      s=Server("http://192.168.1.200/rpc")
      s.relay_set(4,1)
      I am getting always this error:
      File "/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages/jsonrpclib/jsonrpc.py", line 239, in _request
      return response['result']
      TypeError: 'NoneType' object has no attribute 'getitem'
      Raspberry 2 B
      RASPBIAN JESSIE
        Hi, is the relay visible in the web interface or the output of the debugging mode? https://github.com/UniPiTechnology/evok#debugging
          the relay is visible on the web interface and works fine.
          The output of debugging mode is on the attached screenshot.
              Could you please try this workadound? https://forum.unipi.technology/topic/86/relay-command-with-python/3
              I thought that this issue has been fixed...
                chuckhinds last edited by
                I have a Raspberry Pi 3 running Jessie with fresh installation of Evok. I am also using Python 3.4. I received the error, "TypeError: 'NoneType' object is not subscriptable." The workaround Tomas referred to on Nov 25, 2016, worked, but I first had to install jsonrpclib-pelix, a version of jsonrpclib updated for Python 3. The standard jsonrpclib does not work with Python 3.
