    Neuron M203/How to read DI?
    UniPi 1 - HW Q&A
      Massimogai last edited by tomas_hora
      last week I bought a M203. I would like to read the digital inputs with the MODBUS protocol. I tried to use the neuron_tcp_modbus_server with libmodbus but the results are wrong, they change at every reading. Here my code:
          mb = modbus_new_tcp("192.1681.1.102", 502);
          //modbus_set_slave(mb, 2);
          modbus_connect(mb);
          /* Read 16  bit sfrom the address 0 */
          modbus_read_bits(mb, 0, 16, tab_reg);
          modbus_close(mb);
          modbus_free(mb);
          for (int i = 0; i < 16; i++) {
          std::cout << static_cast<uint8_t>(tab_reg[i]) << std::flush;
          std::cout <<",";
      Any suggestions?
      Thanks.
        make sure set the slave to 2 as you had. Also double check the documentation, coils for DI using slave 2 are from coil 14 up to 29. You are reading coils 0-15.
        Br,
