Navigation
    evok on Neuron
    9
    19
    6803
      mauri last edited by tomas_hora
      Hello
      i'm testing the Neuron S10x with the evok software.
      i installed evok, attached an 1Wire temperature sensor DS18B20, on a the evok WebInterface i see the correct temperature. so far so good.
      If i now slide the Analog Outup slider arround, nothing happens on the AO port of the Neuron. The multimeter don't show any value.
      I suppose that the /etc/evok.conf i not correct. I played arround but get no significant results.
      can you provide me e correct configuration for the neuron s10x?
      thanks
      mauri
        I am sorry but evok is not yet completely finished for Neuron. We are doing our best to finish the work. hopefully we will release within the next few weeks.
        • Vesa Kauppinen
          Vesa Kauppinen last edited by
          So how about transistor outputs. Can i manage those with Evok?
          Thank you
          Vesa
            Anything besides the 1Wire in Evok does not work for Neuron at the moment.
            However there is always a possibility to communicate with Neuron using TCP modbus :)
            • _
              _chriz_ last edited by
              do you know already an approximate (realistic) release date for the Evok Neuron API?
              thanks,
              Chris
                Hopefully within two weeks if everything goes well. But do not take it as a promise because we have so much work to do :(
                A 1 Reply Last reply Reply Quote 0
                  Anders Kjellström @tomas_hora last edited by
                  @tomas_hora wats the progress?
                    @Anders-Kjellström we hava a functional beta-version where the Web interface is not complete, but the communication is done (websockets, rest). I could upload that one to github if needed, but functilanlity is not 100% guaranteed.
                      @tomas_hora yes pls
                        chrischnweiss last edited by
                        Hi, are there any updates regarding this topic?
                        Thanks,
                        Christian
                          Hi @tomas_hora, are there any news on this topic?
                          Can you please upload the beta you talked about to github?
                          Would be nice to test it with my Neuron L403.
                          Cheers,
                          Christian
                          • H
                            hellpf last edited by
                            I'm able to do some testing for you if you send me a bata version of evok for my Neuron L203! Thx! I need it, pls!
                              I have pushed the version of evok which support Neurons to GitHub: https://github.com/UniPiTechnology/evok
                              All the APIs shoudl work OK, it not please report to github. But there is a still a lot of work to do on the web interface but basic functionallity (setting on and off) is implemented
                                Work's great for me for now.
                                Thank you very much!
                                Cheers,
                                Christian
                                • H
                                  Works great!
                                  • S
                                    sebastian-azeti last edited by
                                    Any plans on creating a release of this commit? Would be great,. Thank you in advance.
                                      It is still not ready for a final commit. The web has to be cleaned-up and finalized some tools that are not functional. Once done, it will be released under a new version.
                                        Merv last edited by
                                        I meant to post here. I am running the latest version of Evok on the small Neuron and its doing fine. My python application is running for 4 days now with no hiccups.
                                        I only use the Evok gui screen to verify what my application is doing (as well as looking at the LED's.
                                        Merv.
                                          tomas_hora administrators @Merv last edited by
                                          @Merv Thanks a lot for the info!
