    wifi dongle if unit is mounted in a steel cabinet
    General Discussion
    • B
      billj last edited by
      I'm forced to mount the UniPi Neuron M203 unit in a cabinet of steel. If the wifi doesn't pass that cabinet, is there a solution to add an antenna or later on add a wifi solution that is connected via one of the USB connectors. Or in another way?
        Hello, if the internal wifi wont work, you can use USB wifi modem and use external antena. There are plenty models that will work well.
