    hw_definitions file missing in 3.0.1.2 bookworm ?
    • S
      Stoeffel last edited by Stoeffel
      Problem:
      EVOK 3.0.6 installed on UniPiOS 12.20251103.1
      /etc/evok/hw_definitions/ is empty (except Iris modules)
      Missing: 00.yaml, 08.yaml, xG18.yaml, xS11.yaml, xS51.yaml
      evok-unipi-data shows status [residual-config]
      Hardware: Neuron M203 with extensions xG18, xS11, xS51
      What I tried:
      apt install evok-unipi-data-full → only installs Iris modules (IM203, IM204, etc.)
      apt install evok-unipi-data → after purge/reinstall still empty
      Error in EVOK logs:
      ERROR:evok:'readboards: Unsupported device model 00! (check HW definitions)'
      ERROR:evok:'readboards: Unsupported device model 08! (check HW definitions)'
      ERROR:evok:'readboards: Unsupported device model xG18! (check HW definitions)'
      ERROR:evok:'readboards: Unsupported device model xS11! (check HW definitions)'
      ERROR:evok:'readboards: Unsupported device model xS51! (check HW definitions)'
      Are the same like in Evok 2.5. Can i copy them to Evok 3
      Kind regards
      Stefan
        cleve administrators last edited by
        Hello @Stoeffel
        this looks like something/someone erased the definitions. They are not reinstalled, as they are in /etc/ and treated as configuration files. You can try running sudo apt-get -o Dpkg::Options::="--force-confmiss" install --reinstall evok-unipi-data and see if it helps. If not a deeper diagnosis will be needed.
        It is not possible to copy them from 2.x the system was refactored.
        • S
          Stoeffel @cleve last edited by
          @cleve
          Hello Cleve
          Thanks for reply.
          Did what it was supposed to do.
          Thank a lot for your help.
