    Web
      jesus_angulo last edited by
      Hello
      I´m using unipi to monitor a boiler room and I have got some minor problems:
      I have uploaded a web to the unipi board using MERVING IDE and it worked but when I try to replace the web with a new one,it is not replace in the board.
      How can I change the web in the board?
      I want to protect this web with login and password, but it does not work.
        Hello
          Guest last edited by
          is the folder where you upload the web from generated in HMI set correctly in the project in IDE?
          The web username/password is currently bugged but will be fixed soon.
            Hello
            Everything is working fine.
            I need to change the port used by the web server, for example to 8080. I have changed it in mervis ide, and after uploading configuration to the Unipi board and rebooting it has not changed.
            What I´m doing wrong?
              the web port number in IDE is still on our todo list but not functional for now. If you have basic linux skills send me a PM and I will tell you what to do.
              Br,
