    unipi-kernel-modules-dkms (2.76~bookworm) fails to build rtc-unipi.ko
    3 Posts 2 Posters 2.2k Views 2 Watching
      Achilleas Kotsis
      Setting up unipi-kernel-modules-dkms (2.76~bookworm) ...
      locale: Cannot set LC_MESSAGES to default locale: No such file or directory
      locale: Cannot set LC_ALL to default locale: No such file or directory
      Loading new unipi-2.76~bookworm DKMS files...
      Building for 6.6.51+rpt-rpi-v8
      Building initial module for 6.6.51+rpt-rpi-v8
      Error!  Build of rtc-unipi.ko failed for: 6.6.51+rpt-rpi-v8 (aarch64)
      Make sure the name of the generated module is correct and at the root of the
      build directory, or consult make.log in the build directory
      /var/lib/dkms/unipi/2.76~bookworm/build for more information.
      dpkg: error processing package unipi-kernel-modules-dkms (--configure):
       installed unipi-kernel-modules-dkms package post-installation script subprocess returned error exit status 7
      Errors were encountered while processing:
      E: Sub-process /usr/bin/dpkg returned an error code (1)
      make: Entering directory '/usr/src/linux-headers-6.6.51+rpt-rpi-v8'
      make[2]: *** No rule to make target '/var/lib/dkms/unipi/2.76~bookworm/build/rtc-unipi/src/rtc
      -unipi.o', needed by '/var/lib/dkms/unipi/2.76~bookworm/build/rtc-unipi/rtc-unipi.o'.  Stop.
      make[1]: *** [/usr/src/linux-headers-6.6.51+rpt-common-rpi/Makefile:1946: /var/lib/dkms/unipi/
      2.76~bookworm/build/rtc-unipi] Error 2
      make: *** [/usr/src/linux-headers-6.6.51+rpt-common-rpi/Makefile:246: __sub-make] Error 2
        cleve administrators
        Hello @Achilleas-Kotsis,
        why do you use the dkms and not the pre-compiled modules? What is your setup?
        A 1 Reply Last reply
          Achilleas Kotsis @cleve
          @cleve Because I never use precompiled modules on debian based systems if I can help it since dkms was introduced in the '00s, I like the flexibility of not having to match kernels with specific precompiled modules.
          For example, right now on one of my systems:
          unipi-kernel-modules : Depends: linux-image-rpi-v8 (= 1:6.12.20-1+rpt1~bpo12+1) but 1:6.6.74-1+rpt1 is to be installed
          I have multiple rpi3 and rpi4 based neuron systems that I maintain, most are runing raspberry pi os bookworm aarch64. BTW unipi-kernel-modules-dkms=2.70~bookworm builds just fine until at least linux-image-6.6.74+rpt-rpi-v8
