    Re-Calculation of Voltage for AI/AO still valid?
    Neuron Series
    • K
      knebb last edited by knebb
      I own a Neuron M103 (the old one, not the current) which is still running with Raspbian 10/ buster.
      I want to control my AO and read AIs through Modbus with my C-code.
      I remember there was a calculation how to get to the value to be written to the register. Somethins with deviation, offset and so on. Mentioned here. But I was unable (or to dumb) to find any up-to-date documentation.
      Checking the latest register map I see register 3000& 3001 marked as "Basic" for the value.
      So I was able to set (and read later) a voltage to 5V through:
      union   {
              uint16_t word[2];
              uint32_t dword;
              float fl;
      } wert;
      wert.fl = 5;
      ret = modbus_write_registers(connection, 3000, 2, &wert.word[0]);
      Am I right I do not need those mentioned calculations any more and I can set the value (float between 0 and 10)?
      Thanks!
      /KNEBB
        cleve administrators @knebb last edited by
        Hello @knebb,
        we do not provide support for Buster based systems anymore. However, on the latest firmware with BaseOS 12, the value is the actual value (the datatype is real - float32), there is no further calculation needed.
