    How to configure wlan0
    Neuron Series
    • P
      paolo last edited by
      I have just installed Base OS x64.
      The ssh access via eth0 works but I can't configure wlan0.
      I see that the configuration file /etc/wpa_supplicant/wpa_supplicant.conf usually found on Raspbian does not exist on Base OS.
      I've tried editing /etc/wpa_supplicant/wpa_supplicant-wlan0.conf but it still doesn't work.
      Do you have a solution for me?
        cleve administrators @paolo last edited by
        @paolo
        Hello, the problem is that the wlan0 interface is disabled on our units in U-Boot by default. Those are steps to enable and configure the Wi-Fi interface:
        Set up the Wi-Fi parameters:
        sudo nano /etc/wpa_supplicant/wpa_supplicant-wlan0.conf
        Enable wlan0 in U-Boot
        cd /etc/bootcmd.d/
        sudo make enable-wifi
        Set up management (DHCP) on wlan0:
        sudo cp /etc/systemd/network/examples/10-wlan0.network.example  /etc/systemd/network/10-wlan0.network
        A reboot is required to reflect the changes in U-Boot:
        sudo reboot
        R 1 Reply Last reply Reply Quote 1
          riccardooo @cleve last edited by
          @cleve How can I configure IPv4 on eth0? In the previous version, there was a dhcpcd.conf file inside /etc/dhcp/. Should I create this file, or is there another method to set a static or dynamic IP on the Ethernet port?
          Greetings
          Riccardo
            cleve administrators @riccardooo last edited by
            @riccardooo
            it would be better if you create a separate thread for an unrelated issue next time. Our systems use systemd-networkd, it's a standard GNU/Linux daemon, you can refer to Debian/Arch Linux manuals.
