    RS485/M-Bus converter configuration
    Other Peripherals
      t.kavan last edited by
      Hi all, is here anyone with a knowledge to properly setup RS485/M-Bus converter from JC Elektronika?
      My testing setup:
      • Unipi Patron M527 with Patron Node RED OS installed and libmbus 0.8.0,
      • 80 device version of RS485toMBus-XL connected to 1.3 port RS485,
      • Electricity meter Inepro PRO380Mb (Addr set to 9, Bdr set to 1200).
      mbus-serial-scan tool seems to find the meter:
      unipi@M527-snXXX:~$ mbus-serial-scan -d -b 1200 /dev/ttymxc0
      Scanning primary addresses:
      9 [2024-06-09 09:23:07] SEND (005): 10 40 09 49 16
      [2024-06-09 09:23:07] RECV (001): E5
      Found a M-Bus device at address 9
      but mbus-serial-request-data tool is not able to read response:
      unipi@M527-snXXX:~$ mbus-serial-request-data-multi-reply -d -b 1200 /dev/ttymxc0 9
      main: debug: sending init frame
      [2024-06-09 09:15:20] SEND (005): 10 40 FF 3F 16
      [2024-06-09 09:15:21] SEND (005): 10 7B 09 84 16
      mbus_sendrecv_request: Failed to receive M-Bus response frame.
      mbus_frame_print: Dumping M-Bus frame [type 0, -3 bytes]:
      Failed to generate XML representation of MBUS frames: M-bus data parse error.
      If I use M-Bus master from ENBRA (USB-MBus) CODMBUS the read tool is ok to read the meter:
      unipi@M527-snXXX:~$ mbus-serial-request-data -d -b 1200 /dev/ttyUSB0 9
      [2024-06-09 09:05:30] SEND (005): 10 40 FF 3F 16
      [2024-06-09 09:05:30] SEND (005): 10 7B 09 84 16
      [2024-06-09 09:05:31] RECV (081): 68 4B 4B 68 08 09 72 08 05 08 21 CD 25 01 02 2D 00 00 00 0C 04 61 77 26 00 8C 10 04 61 77 26 00 8C 20 04 00 00 00 00 1C 04 61 77 26 00 9C 10 04 61 77 26 00 9C 20 04 00 00 00 00 2C 04 00 00 00 00 AC 10 04 00 00 00 00 AC 20 04 00 00 00 00 83 16
      mbus_frame_print: Dumping M-Bus frame [type 4, 81 bytes]: 68 4B 4B 68 08 09 72 08 05 08 21 CD 25 01 02 2D 00 00 00 0C 04 61 77 26 00 8C 10 04 61 77 26 00 8C 20 04 00 00 00 00 1C 04 61 77 26 00 9C 10 04 61 77 26 00 9C 20 04 00 00 00 00 2C 04 00 00 00 00 AC 10 04 00 00 00 00 AC 20 04 00 00 00 00 83 16
      <MBusData>
          <SlaveInformation>
              <Id>21080508</Id>
              <Manufacturer>INM</Manufacturer>
              <Version>1</Version>
              <ProductName></ProductName>
              <Medium>Electricity</Medium>
              <AccessNumber>45</AccessNumber>
              <Status>00</Status>
              <Signature>0000</Signature>
          </SlaveInformation>
          <DataRecord id="0">
              <Function>Instantaneous value</Function>
              <Unit>Energy (10 Wh)</Unit>
              <Value>267761</Value>
              <Timestamp>2024-06-09T09:05:31</Timestamp>
          </DataRecord>
      I would appreciate any idea what I'm doing wrong. Thanks!
        AVsetula last edited by
        Hi @t-kavan,
        We have already encountered this, unfortunately this meter does not wait for the prescribed time and responds too quickly, so that the RS485 (transmit/receive) state in the controller does not have enough time to change.
        The RS485 behaviour was modified in later versions of the debian packages. With the current OS image the PRO380-MB meter are already working.
        Antonín Všetula - Unipi technician
