    CM4 + nvme SSD + unipi 1.1 + node red image bootup error
    Node-RED
    • P
      PEPITO82 last edited by PEPITO82
      Hi all,
      I'm currently experimenting to run my unipi 1.1 board with a raspberry compute module 4 and a nvme SSD with the official unipi 1.1 node red image (https://kb.unipi.technology/en:hw:03-unipi11:download-image:02-nodered).
      Basically the node red image would work, but only if I boot it from SD card or emmc. May aim, however, is to boot it from the nvme SSD directly.
      During bootup from nvme SSD, I'm getting the following error:
      RPI bootup screenshot
      Can someone help me to get this fixed?
      Regards,
      Peter
      • P
        Here again the screenshot.
        RPI bootup error
        Alternativly as link:
        RPI bootup error
          AVsetula last edited by
          Hello PEPITO82,
          The RPi CM4 is currently not an officially supported platform. However, according to my information, should be mostly compatible with "standard" RPi.
          One option may be to use the RaspberryPi OS image and install the necessary components: EVOK, Node-RED.
          If you also want so-called Unipi nodes for communication with inputs and outputs, which are available in our Node-RED OS image, just add a suitable module from the palette to Node-RED.
          Antonin
