    "UNIPISPI: SPI CRC2 Not Correct" - why?
    Neuron Series
    • K
      knebb last edited by knebb
      I noticed recently these messages in my syslog:
      Apr  9 08:53:33 zentrale kernel: [  200.867042] UNIPISPI: part1 b3:07:00:00
      Apr  9 08:53:33 zentrale kernel: [  200.972499] UNIPISPI: SPI CRC2 Not Correct: 2108 COMPUTED: 23f8
      Apr  9 08:53:33 zentrale kernel: [  200.972524] UNIPISPI: len=36, part1=fa:00:55:0e part2=00:82:00:a0:09:c5:80:00:00:00:00:00:00:00:00:00
      Apr  9 08:53:33 zentrale kernel: [  200.977253] UNIPISPI: SPI CRC2 Not Correct: 3200 COMPUTED: 10e5
      Apr  9 08:53:33 zentrale kernel: [  200.977276] UNIPISPI: len=42, part1=fa:00:55:0e part2=01:01:04:c0:00:00:00:0c:00:00:00:11:e5:00:40:00
      Apr  9 08:53:33 zentrale kernel: [  200.979490] UNIPISPI: SPI CRC1 Not Correct (Received: 0000 Calculated: 9b77)
      I understand there is some CRC32 mismatch possibly related to some SPI device.
      But what does it mean in detail and how can I prevent this message- or is something seriously broken?
      I haven't noticed anything not working- but I am not using SPI devices (afaik).
      Thanks in advance!
      /KNEBB
      • K
        meanwhile I found a "solution" based on this post.
        I did an
        apt-cache policy unipi-kernel-modules
        which revealed the available version names.
        Followed by
        apt install unipi-kernel-modules=1.106.1.20220308~buster-1
        it installed the previous version and all is smooth again.
        Still, this is a workaround but not a solution.
        /KNEBB
        1 Reply Last reply Reply Quote 2
          tonytee last edited by
          i'm experiencing the exact same problem on a freshly flashed SD card with neuron-node-red_image-20220406.0.zip
          @knebb your tip fixes this, so thanks for that.
          i guess it probably needs a more structural fix, so hopefully this will be included in the next available flash image...
          thanks anyway for posting this... it fortunately solves my problems without a lot of haystacking
          Cheers, Tony
            rob last edited by
            Same problem still present on neuron-node-red_image-20220412.0, see here for details
            Thanks to you @knebb I am now able to use my system again. Let's hope they fix this soon.
            rob
            • K
              knebb @rob last edited by
              @rob
              I just upgraded to unipi-kernel-modules 1.112.1.20220308~buster-1 and it looks like they fixed the error.
                AVsetula last edited by
                Hi everybody,
                It has been fixed with a new version of the unipi-kernel-modules package.
                At the same time, we increased the output testing of packages.
                Antonin
