    clearTimeout not working ?
    Node-RED
    1
      TARIK DR last edited by
      the code must start 2 actuator with delay 3 s in between en every actuator use 2 relays to change diriction
      the problem that i can not reset the timeout to close or open the cleartimeout is not working any help plz
      function init() {
       function func_delay(myfunction,circuit,value,timer)
                this.timer1 = setTimeout(function(){ this.timer2 = myfunction;
                 node.send({payload: cmd_build(circuit,value)}); }.bind(this), timer);
              function stop()
                 node.warn(this.timer1);
                 node.warn(this.timer2);
                 clearTimeout(this.timer2);
           function router(data ){
             switch(data) {
                   case  triggers["START_ZONE1"] :
                     node.warn("Zone 1 status Started ");
                stop();
                   func_delay(func_delay(null,relays["zone1v2_open"],actions["on"],3000),relays["zone1v1_open"],actions["on"],1000);
                    node.send({payload: cmd_build(relays["zone1v1_close"],actions["off"])});
                    node.done();
                    node.send({payload: cmd_build(relays["zone1v2_close"],actions["off"])});
                    node.done();
                  msg={topic: "zone1/valves/opening",payload:{"notif":"notif_v1_stat", "message":"zone 1 started"}}
                  node.send(msg)
                  node.done();
                // return [null,msg] ;
               // node.warn(msg);
             break ;
          case  triggers["STOP_ZONE1"] :
               stop();
                func_delay(func_delay(null,relays["zone1v2_close"],actions["on"],3000) ,relays["zone1v1_close"],actions["on"],1000);
                node.send({payload: cmd_build(relays["zone1v1_open"],actions["off"])});
                node.done();
                node.send({payload: cmd_build(relays["zone1v2_open"],actions["off"])});
                node.done();
                msg={topic: "zone1/valves/closing",payload:{"notif":"n1", "message":"Zone 1 stoped"}}
                node.send(msg)
                node.done();
               break ;
             default :
      init();
        TARIK DR last edited by TARIK DR
        after many trys i fund the solution i created the object that contain the timer and the 2 methods start and stop
        var newLocal = null;
        const myAction = {
            timer: newLocal,
            start : function (timerr)
                   return this.timer = setTimeout(function(){
                    node.warn (cmd_build("circuit",1)); }, timerr);
              stop : function (timer)
             return clearTimeout(timer);
