    Power Supply Unipi 1.1 and RPi
    Unipi 1 - First Generation
      M1che1 last edited by
      Do you need to supply both with their own power supply or do you only need to supply the Unipi? -- Will the Unipi supply power to the Raspberry?
        Martin Kudláček @M1che1 last edited by
        Hello @M1che1,
        the Unipi 1.1 has been designed for needs of Raspberry Pi 2. Since then, the RPIs got more power hungry and the internal connections might not be suitable for powering both the RPI and the Unipi 1.1. That depends on what RPI you are using and what you are running on the RPI. It is definitely safer to use separate power supplies.
