    1-Wire 8 port hub, switched star topology
    Scheduled Pinned Locked Moved Other Peripherals
    2 Posts 2 Posters 1.3k Views
      Csevi
      I have to use star network topology due to the local conditions in my installation. Unfortunately the lines are long and with different lengths. I use several 1-Wire temperature sensors (DS18B20) witch works fine individually but not with together.
      So, I have to use switched network for for reliability.
      My question is: The 1-Wire 8 port hub is a active (switching hub)? Is it suitable for me?
      (The 1-wire master is from different manufacturer).
      Thanks in advance,
      Istvan
      • Martin KudláčekM
        Martin Kudláček @Csevi
        Hi @Csevi,
        in short - the 1-Wire hub is passive device, which helps with the "linearization" of the star topology. You can find complete information about 1-Wire here: https://kb.unipi.technology/en:automation:02-glossary:1wire-hidden
