Electric potential
I want to give 12V to the D Input from a different source.
So I have to connect the GND from my source to the 12V GND to zero the Electric potential.Where can I get the 12V GND?
F-S
F-S
Using different PSU is described in technical documentation, see https://files.unipi.technology/index.ph ... niPi%201.1
Depending on what DI you want to use with the other PSU you will have to switch JP2 and JP3 at minimum.
