    RS232 GND pin
    Scheduled Pinned Locked Moved Axon series
    2 Posts 2 Posters 1.2k Views
      rtatibouet
      I own an Axon S215.
      I want to use the RS232 interface with a 12V RFID reader.
      How should I use the "GND" pin for RS232 on the Axon ? Do I need to use it ?
      I use another reader (12V as well) with the RS485 interface, but this one has no "GND" pin.
      Thanks !
      • Martin KudláčekM
        Martin Kudláček @rtatibouet
        Hello @rtatibouet,
        the RS485 and RS232 are completely different buses.
        The RS485 is differential and doesn't need the GND, since the logic levels are based on the voltage difference between A and B terminal
        The RS232 is not differential and the TX / RX logic levels are based on the voltages between TX and GND and RX and GND.
