    LTE connection problem on M265
    Axon series
      daminou53 last edited by
      I am trying to configure my 4G interface on my unipi M265.
      The connection is not made and I have the following logs:
      2019-02-14 11:31:35,910 - DEBUG - Waiting for IP assign...
      2019-02-14 11:31:39,933 - DEBUG - b'3: wwan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000\n    link/ether 02:00:03:19:00:0b brd ff:ff:ff:ff:ff:ff\n'
      2019-02-14 11:31:39,934 - DEBUG - Waiting for IP assign...
      2019-02-14 11:31:43,954 - DEBUG - b'3: wwan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000\n    link/ether 02:00:03:19:00:0b brd ff:ff:ff:ff:ff:ff\n'
      2019-02-14 11:31:43,955 - DEBUG - Waiting for IP assign...
      2019-02-14 11:31:47,978 - DEBUG - b'3: wwan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000\n    link/ether 02:00:03:19:00:0b brd ff:ff:ff:ff:ff:ff\n'
      2019-02-14 11:31:47,979 - DEBUG - Waiting for IP assign...
      2019-02-14 11:31:51,984 - ERROR - Cannot obtain IP address from LTEs DHCP server...
      2019-02-14 11:31:51,986 - INFO - Modem init complete
      2019-02-14 11:31:52,589 - INFO - Registered to: Orange F Network type: 7 RSSI: 19 Sigqual: 6
      2019-02-14 11:31:58,599 - DEBUG - WAN IP 10.34.177.115, Private IP 10.21.8.1; NON-CONFLICT
      2019-02-14 11:31:58,600 - INFO - WAN IP ADDRESS: 10.34.177.115 INTERFACE IP ADDRESS: 10.21.8.1
      2019-02-14 11:31:58,602 - DEBUG - RSSI: 19 sigqual: 6 net-type: 7
      2019-02-14 11:32:00,023 - INFO - unipi-lte version 0.18 from 2019-02-14 11:11:00.068002 - Logging started..
      2019-02-14 11:32:00,024 - DEBUG - Config file /etc/unipi/lte.conf parsed
      2019-02-14 11:32:00,025 - DEBUG - CURRENT SETTINGS: {'_was_changed': False, 'apn': '"orange"', 'auth_method': 1, 'auth_user': '"orange"', 'auth_pass': '"orange"', 'pin': '0000', 'usbmode': '2', 'report_period': 86400, 'oneshot': False, 'regtimeout': 120, 'suspend_timeout': 43200, 'lte_autokeep_on': True, 'lte_iface': None, 'ping': {'active': False}}
      2019-02-14 11:32:00,029 - DEBUG - Entering the main loop...
      2019-02-14 11:32:00,036 - INFO - Created wwan0 iface file
      2019-02-14 11:32:00,659 - INFO - Pin resolved
      2019-02-14 11:32:00,963 - DEBUG - USB profile remains the same
      2019-02-14 11:32:01,265 - DEBUG - APN remains the same : "orange",0,0,0,0,0,0,0,0,0,1,0,0,1,0,0,0,0,1,"orange","orange"
      2019-02-14 11:32:01,285 - DEBUG - b'3: wwan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000\n    link/ether 02:00:03:19:00:0b brd ff:ff:ff:ff:ff:ff\n'
      2019-02-14 11:32:01,303 - DEBUG - Ifup !!!
      2019-02-14 11:32:01,327 - DEBUG - Ifup OK!!!
      2019-02-14 11:32:01,344 - DEBUG - b'3: wwan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000\n    link/ether 02:00:03:19:00:0b brd ff:ff:ff:ff:ff:ff\n'
      2019-02-14 11:32:01,346 - DEBUG - Waiting for IP assign...
      2019-02-14 11:32:05,368 - DEBUG - b'3: wwan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000\n    link/ether 02:00:03:19:00:0b brd ff:ff:ff:ff:ff:ff\n'
      2019-02-14 11:32:05,369 - DEBUG - Waiting for IP assign...
      2019-02-14 11:32:09,394 - DEBUG - b'3: wwan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000\n    link/ether 02:00:03:19:00:0b brd ff:ff:ff:ff:ff:ff\n'
      2019-02-14 11:32:09,396 - DEBUG - Waiting for IP assign...
      And here is the configuration file:
      ; !!!! DO NOT USE # FOR COMMENTS !!!!
      ; Keep at least one trailing <space> following each value (e.g. 3600 ; a comment can be here)
      [MAIN]
      pin: 0000 ; Uncomment and set it if SIM pin is active (ignored if SIM is not pin-protected).
      apn: "orange" ; APN (depends on your provider)
      auth_method: 1 ; PPP Authentication: 0 - no auth.(default), 1 - PAP, 2 - CHAP
      auth_user: "orange" ; Username for PAP/CHAP auth methods
      auth_pass: "orange" ; Password for PAP/CHAP auth methods
      usbmode: 2 ; 2(default) for CDC_ECM + 3x CDC_ACM, 3 for RNDIS + 1x CDC_ACM (see AT Command manual of the LTE module)
      oneshot: false ; LTE modem initialization only. Close ttyACM and exit the dameon. No LED handling! Default: FALSE.
      reg_timeout: 120 ; In seconds
      suspend_timeout: 43200 ; In seconds (e.g. 86400 = 24 hours),-1 = suspend forever (goes to HALT mode)
      report_period: 86400 ; In seconds (e.g. 86400 = 24 hours)
      auto_keepon: true ; Automatically up the LTE network interface if it goes down accidentally.
      [LOG]
      path: /var/log/unipilte.log ; If not defined (commented), syslog is used instead of an user file
      severity: debug ; Severity threshold - debug, info, warning, error, cititical
      logfile_size: 131072 ; Meaningless if syslog is used
      [PING]
      active: False ; True
      primary_iface: eth0 ; Primary WAN interface. The LTE connection is always a backup one.
      fail_threshold: 3 ; Default: 3
      ip_eth: 8.8.8.8 ; Adress that the daemon pings to via eth0
      ip_lte: 8.8.8.8 ; Adress that the daemon pings to via lte_interface
      period: 4 ; Ping period given in 10 sec timesteps; 0 - every 10 sec
      timeout: 2 ; Wait for pong in seconds
      packetsize: 2 ; Payload size in ping packet
      autoswitch: true ; MAIN/BACKUP iface switching - set false if LTE is the primary and the ONLY active interface
      ; Config file signature - do not modify it nor add any lines or whitespaces!
      ; ad66eb178c6b02b7371462faa98d207a
      Is there any documentation for using this service?
      Regards,
        Hello @daminou53 ,
        what OS image are you using? Have you done any changes in network configuration (e.g. /etc/network/interfaces files)?
        On the following lines, the connection is successfully initialized (probably with very poor signal quality) but immediately, the LTE service is restarted.
        Are you able to provide remote access to the unit?
        In the meantime, you can try to install the new beta version:
        sudo apt install unipi-lte=0.19*
