    Modbus RTU - NeuronL503 - Mervis
    • O
      OlivierP last edited by OlivierP
      Hi all,
      I'm used to working with Codesys and I can't find my way fully around Mervis yet :)
      So I am trying to read out some PPM CO2 readings from a Modbus RTU transmitter
      • Datasheet: http://downloads.epluse.com/fileadmin/data/product/ee870/BA_EE870_e.pdf
      • I'm trying to read out the CO2 fast parameter: Address: 29 + 30
      It seems I can read out some values, but I have to combine them into a REAL, in Codesys I use UNION to combine both words (and swap them) into a REAL.
      What is the easiest way to achieve this within Mervis?
      Thank you.
        Martin Kudláček last edited by
        Hi @OlivierP ,
        you can change the byte order via MultiByte Order:
