    Unipi 1.1 - how to set relay output in NODERED
    Node-RED
    • W
      wizro_pl last edited by wizro_pl
      HI!
      What should I write in configuration to set relay output for Relay 1 ?
      Unfortunately, I tryied many combination without result.
      this workaround in first diagram works,
      where I sent in Function
      msg.headers = {};
      msg.headers={
          'Content-Type': 'application/x-www-form-urlencoded'
      msg.payload = {};
      msg.payload={
          'value': '1'
      return msg;
      as HTTP request POST for url. http://(myadresip_evok)/rest/relay/1
      but second base on UNIPI Output doesn't work
      Can you help me with that?
      W 1 Reply Last reply Reply Quote 0
      • W
        wizro_pl @wizro_pl last edited by
        @wizro_pl up?
          Martin Kudláček @wizro_pl last edited by
          Hi @wizro_pl,
          you need to write a boolean value: true or false.
          • W
            Sorry,
            it doesn't work
            for Uni Pi 1.1 - realy no 2 should be configured like that: ?
            • W
              ok, I solved the problem.
              it is logic but a little strange because UniPi Output only prepare the JSON message, but to send it you still need websocket ( I thought that UniPi Output node handle all of it).
              it works
