Proximity sensors
Hi all, I would like to build smart home with couple of Axons and I am struggling with finding a proper proximity sensor. Regular PIR sensors are designed for 230 V and are relay-like (for direct light switching). Do you have any hint where to get 24 V proximity sensor with output compatible with Axon digital input?
Thank you
Dalibor
Hi @dalibor,
we typically sort this out by connecting 24V to the contact 11 of the PIR's relay and connecting the contact 14 (NO) to the DI. Would that pose some problem in your installation?Best regards,
Hi @Martin-Kudláček, thank you for answer. Sounds good!
PS: Is there a way, how to set pull-up/down for this digital input in Axon?
Hi @dalibor,
no, the DIs don't have this capability. Mainly because it would require to have DIVCC terminal, to ensure galvanic isolation.
